Rejected for technical issues. Please help me understand the problem
  • March 11, 2019
  • 792 views
Correct answer jacquelingphoto2017
Hi carlosmartin
Nice picture, with one exception; you did not capture more of that green area. Hence you have a bad framing and that is a reason for technical error rejection.
You should either have all sky, or more of the green area more to the base rather than in a small corner.
Regards
JG
Ricky336
I agree with Jacquelin, your composition isn't good. It's top heavy. It's weighted down too much (the ground) on the left of the frame.
From Adobe:
Quality and technical issues rejected at Adobe Stock
Technical issues
When we reject a file based on technical issues, we have identified technical flaws other than focus, exposure, or artifacts, which we call out specifically.
General composition: Is your horizon straight? Have you cropped the image too much? Consider leaving a designer room to add their own text or objects.
___________________________________________________________________________________________________________
Therefore, I think in this situation the 'Technical issues' would come under composition.
Thank you very much Jacqueline and Ricky for the comments.
The composition of the image is not, effectively, counterbalanced, but this effect is done on purpose thus leaving a large space for text or other graphic material related for example with prehistory, the green planet, humanity, the environment ... The composition itself,  alone, I agree that it is not correct.
Another image of this same style and composition was recently accepted. So, finally, I do not know if contributions of this type will be accepted in the future.
Thanks again for the feedback and your time.
Ricky336
Just for comparison if you like, could you post your accepted one? We could then compare and contrast the differences between them.
jacquelingphoto2017
jacquelingphoto2017Community ExpertCorrect answer
Hi carlosmartin
Regards
JG
