Nancy OShea
jacquelingphoto2017
Hi @Bahadır5EEA ,
None of your photos' subjects are completely focused. It appears you did not have correct settings for f-stop. The fourth one is also noisy and underexpose.
Best wishes
JG
Photographer and Nutrition Author
Abambo
Check the focus, your pictures are out of focus. It is important that your subjects are in-focus. With the first picture for example, a little part of the stem of the right flower with the fly is in-focus, instead the fly and the blossom.
If you are new to stock, you should consider these resources: https://helpx.adobe.com/stock/contributor/tutorials.html
Please read the contributor user manual for more information on Adobe stock contributions: https://helpx.adobe.com/stock/contributor/user-guide.html
See here for rejection reasons: https://helpx.adobe.com/stock/contributor/help/reasons-for-content-rejection.html
and especially quality and technical issues: https://helpx.adobe.com/stock/contributor/help/quality-and-technical-issues.html
