teresac3415215
In Adobe Captivate 9, my slides look perfect in filmstrip, but parts of grouped objects are missing or misaligned in preview. I've corrected over and over and can't get a fix. Ideas?
  • May 10, 2017
  • 288 views
Adobe Captivate 9.0.2.437
Firefox browser on Macbook Pro
I started with a Chic theme and changed colors.
    Lilybiri
    Are you talking about a normal or a responsive project? Can you post some screenshots?
    teresac3415215
    This is a responsive project. Here is the filmstrip view.
    And here is the preview of the same slide:
    Notice the fill-in-text box has moved and the grouped text/shape submit button is messed up.  Thanks for your help.
    Lilybiri
    Sorry, you cannot attach files, you can only insert images/screenshots using the image button in the Browser version:
    Responsive, means I would have to check the Position Properties. Did you set up each breakpoint view?
    Again, apologize, because now I see that you post this in the portal, not directly in the Jive forums for which I show the browser toolbar. Think you need to use the Media button in the portal (never worked for me).
