Color Shift Going going from LR to PS using Benq Monitor
I recently started editing in LR and PS using a Benq monitor connected to an iMac.
When I do edit-in from LR to go to PS the colors in PS do not match the ones in LR. I have PS set to Prophoto RGB.
Monitor was recently calibrated.
If I move the PS panel to the iMac and back to the Benq the color problem appears to be corrected.
Thoughts?
Thanks
