Audio doesn't work over Remote Desktop
  • December 15, 2019
  • 5932 views
Whenever I connect to my computer using Remote Desktop, audio works for every other program, even Adobe programs, but not for Premiere Pro. I've made sure the audio works on my actual PC, but whenever I try to do work on my laptop, no audio plays whatsoever. It's driving me nuts!
Correct answer
Known issue with RDP
Use VNC or Radmin
https://helpx.adobe.com/premiere-pro/kb/known-issues.html
DGinz
I have the same problem with After Effects. No audio while working with remote desktop. All other apps/  internet browser / video players working perfectly. Is this a known issue that is beeing worked on?
charlesd17592708
That's not an answer to this. RDP works fine for all others. And it worked fine until update. The answer is for Adobe to fix the update.
Same problem.  Has there been a fix?
I found not a fix nor a workaround, but a setting in Premiere that allows audio over RDP. See this reply in another thread: https://community.adobe.com/t5/premiere-pro-discussions/can-t-get-premiere-pro-to-open-in-a-remote-desktop-session/m-p/11424807#M298151
Correct answer
December 15, 2019
Use VNC or Radmin
VNC has the same exact issue--audio works fine for every other program except for Adobe Premiere Pro.
