Bug: Using Export Frame on clips with proxies (even if proxies not toggled), results in low res JPG
  • January 24, 2023
  • 66 replies
  • 2218 views
Using Export Frame on any clip with a proxy attached (even if proxies not active) results in JPGs and PNGs in the proxy-resolution. This seems to happen at random.
During some troubleshooting, oddly it seemed to matter which window (ie Program, Timeline, etc..) was active (highlighted in blue) but this actually reversed between different projects, and ultimately using Export Frame results in low-res and full-res frame grabs at random.
Clips that don't have proxies don't seem to have this issue.
Native media in my examples were .mxf and .mp4
Hello @mberna,
Thanks for the message. It’s been a long time since you filed this bug. I apologize for the lack of a response. Are you still having this issue? It looks like a dev marked this bug as "Started," so I'm wondering.
I'll move your post to the Discussions board while we await your information.
I am also having the same issue!!!!! 😞 What the heck ADOBE!!!!!!
This is something that needs to be fixed 100% without a question!
Seriously Adobe!????
I am also freaking out. Frame exports are always Proxies now. Seen this bug in earlier versions, and it occured randomly. Now it occurs always, when using proxies in a project, no matter if they are turned on or off!!!
FIX this ASAP!!
Tried to workaround by using CTRL+M to export JPGS, but know what? The Marker in the export Window doesnt move to the playhead position anymore.
Why is that??
There is no way to export High Quality Frame Grabs at the moment in a reasonable workflow way, without loosing tons of times.
Can´t believe that.
Procrastinator
Still happening.
Simmo1985
Two years on and still occurring. A shame this hasn't been addressed.
Wow, this just happened to me to and I was freaking out that somehow proxies were being used in some of the video exports. As long as it's only photos, not a huge deal for me, but a pain for sure.
this has been occurring for years. please fix this.
rranney
Still experiencing this issue like many others. When proxies are attached (but not enabled in the program monitor), any export frame command results in proxy-resolution frame grabs. I toggle the Proxy Button on and off in the Program Monitor and sometimes can get a full-resolution export frame, but it seems random. Have tried JPG, PNG, TIFF to all the same result. Would love to see this fixed!
the-visuals-team
Also having this issue. Mind blowing.
