motion array presets not importing into premiere pro issue
  • November 7, 2023
  • 334 views
hi everyone i bought a preset from motion array but it dosen't import into premiere pro for some reason,
the file type is (prfpset)  any help thank you.
Peru Bob
As Ann Bens said, contact Motion Array.
There may be an update.
Presets are usually imported via the Effects tab.
If not contact MA.
Eli loukAuthor
well i know that you import via the effects tab it dosen't work tho
