rachelcenter
reveal in project not working and files not showing up in bin AGAIN
  • January 22, 2023
  • 2020 views
Issue resurfaced again last night. I had 2 projects open at once. I went into "Project A" and copied some clips from "Timeline 1", then went to a timeline in "Project B" called "timeline 2" and hit paste. and the clips showed up on my timeline. but when I right click the clip on the timeline and press reveal in project, it shoots me to the project area and an empty folder. I did a search for the file name verbatim in premiere and nothing comes up in the search even though I can see the clips on my timeline. The clips are 4k. So because I'm not able to access them in the project panel, theres no way to right click on them to choose "create proxy". I sent the project file and media to a friend who was using a PC and not a mac, and he said he experienced the same problem as me. This seems like a bug (i'm using adobe premiere 23.0.0 build 63).
The files are hidden. just right click on project window and click see hidden. 🙂
Warren Heaton
I just tried copying and pasting from Timeline 1 in Project A to Timeline 2 in Project B and the pasted clips showed up immeidately in the Project B tab.  This is Premier Pro 23.1 (Build 86) under macOS 11.7.1.
Reveal in Project from the Clip Boundaries in either Timeline 1 or Timeline 2 go to the source as expected.
rachelcenter
I'm in 23.0.0. (build 63). I wont update to 23.1 because when I did a few weeks ago everything played laggy so i downgraded back to 23.0.0. Can you try in 23.0.0. and see what you get?
Warren Heaton
@rachelcenter
Since rolling back to 23.0 requires uninstalling 23.1, I'm afraid I cannot test that version for you.
I tried the same thing in Premiere Pro 22.6 and Premiere Pro 15.4.5.  Each behaves as expected.
Some things you can try on your end:
  • What happens if you tab over to Project B prior to doing the paste to Timeline 2?  Before doing the paste, I see only one item (Sequence 2) in the Project B tab before the paste and then the source footage included in the copy action after the paste.
  • What happens if you close Project A immediately after the paste to Timeline 2 in Project B?  So, go to the Project B tab pop-up menu and choose Close All Other Projects.
  • Have you tried exporting a selection as Premiere project?  Right-click the Timeline 1 Sequence and then choose File > Export > Selection as Premiere Project....
have checked your autosave folder?    Maybe try copying the sequence from Project A to Project B and then copying and pasting between timelines...  You may have discovered a bug.  I've done this many times but not in Premiere 23.  I'm stuck in Premiere 22 on my 2012 MacBookPro, and haven't been working on the windows machine in Premiere 23 cause sometimes I need to take a project on the road with the macbookpro...
rachelcenter
I did paste between the 2 timelines.
but were both timelines in the same project?  Just guessing that copying the contents of a timeline BETWEEN projects might be problematic...
