Aug 23, 2011 3:29 PM UTC
Does cfgrid have a max result from a query it will display?
My DB has 100 unique items and it just stops at the 90th item.
NO errors just does not show the last 10 items.
I am Using a .CFC
I have no max results set in the Grid.
Grid Format is HTML.
89th & 90th row looks good in the DB..
About 2.5 second load time on Godaddy shared hosting.
Thank you.
    Aug 23, 2011 4:47 PM UTC
    OK, part of your troubleshooting this should be to factor-out elements that are not relevant to the issue, and pare it back to the minimum amount of code that demonstrates the problem.  If you can't work out from that reproduction case what the problem is, post the reproduction case here so we can look at what you're doing. Your repro code should not have any external dependencies like DB connections (so, like, generate the sample data with code).
    Adam
    Aug 23, 2011 11:35 PM UTC
    Thanks for the replies. If there is no restrictions on how
    many records a HTML CFGRID will display then it is some thing in my code.   It is just weird because I have not touched
    the code in weeks I just hit 100 records in my admin section and decided to look
    at my user side.  I deleted a bunch of
    records in the sql database to see if maybe I had some issues within one of
    them with. No luck. The deleted rows did disappeared from my grid results.  Even after I add them back in they now do
    not show up.. Copying a row in the table same result. I am now down to 83 records displaying. I have a separate page
    with the same query placing the data into a table. It works fine. I am also
    running it on my dev machine at home and pulling the data from the Godaddy SQL server. Same issue on my home box.  I am
    going to reduce down the query of the CFGRID as well as move the database to my
    local box.  The only thing I have done
    recent to the .cfc was add a date field. I am using:
    CONVERT(VARCHAR(11), VinyardId.DateUpdated, 101) AS date
    in the Select option of the query to formatingt the date. I
    removed this and receive the same result.
    I will keep trouble shooting.. Who knows maybe I will be
    lucky and they will reboot the servers and it will be working again..
    Thank you,
    - Scott
    To: Scott Pelletier <scott_pelletier@yahoo.com>
    Sent: Tuesday, August 23, 2011 9:48 AM
    Subject: Does cfgrid have a max result from a query it will display?
    Adam
    Aug 29, 2011 9:56 PM UTC
    What happens if you call the URL that the grid is calling directly in your browser?  It'll be in JSON, but you should be able to eyeball it and see if what's being returned from the remote call is correct, and then getting munged by the grid; or whether the grid is rendering everything it's getting and for some reason you're not getting the data you're expecting.
    Adam
    Aug 23, 2011 4:25 PM UTC
    We use applet grids and display hundreds if not thousand of records.  We also use scroll bars on the grid.
