How to fix problems validating serial number for Acrobat XI Pro?
Jun 14, 2016 Jun 14, 2016
I have a PC with Win 7 OS.  I purchased Acrobat XI Pro over a year ago but had problems validating its serial number so I just continued to use X Pro.  Now I have installed XI PRO.  I have been unable to enter its serial number.  When I try to start the program, I find a box appears on my screen.  It contains  and I cannot , I am asked to validate my serial number. Here is a picture of that box.  The dropdown list on the left does  not contain Acrobat XI Pro, but, curiously, the label in the upper left confirms that this box appeared from the program Acrobat XI Pro.   Very Odd.  Does anyone know any other way to validate the serial number?
TOPICS
Acrobat SDK and JavaScript
866
Adobe Employee , Jun 14, 2016 Jun 14, 2016
Hi 2722Ellie ,
It seems that the Acrobat XI pro program which you have is an upgrade version.
For this please refer to this KB article :- Error: "This serial number is not for a qualifying product" | Adobe Creative Suite
Let me know how it goes.
Yatharth
Votes
Adobe Employee ,
Hi 2722Ellie ,
Yatharth
Votes
