As of Adobe AIR SDK 19.0.0.213, there are a few notable compiler bugs that could use some attention. The compiler is accidentally compiling the code, when it should not be. The runtime finally catches the errors when the bad code tries to execute, but it would be much more efficient for the compiler to check for these problems at the time of coding.
An interface issue with the compiler not being able to recognize the difference between a getter and a regular method:
Bug#3935211 - ActionScript compiler 2.0 is mismatching interface getter for method
Here is another compiler bug that also could use some attention about constructors:
When will these bugs get put on the roadmap?
