I downloaded town of salem off steam, when i tried to run it it said i needed to get/update adobe air, so i though thats not too hard, when i procceded to download it and install it a message came up saying "An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator." i searched all over your fourms and one thing kept coming up, download microsoft fix it. So i did, i ran it and uninstalled adobe air from my computer, because i already had a older version. Then following the fourms guidlines i re-downloaded adobe air installer and it still didnt work. Im very much so angry at this so please help me. Here is my logs
[2014-12-30:20:17:59] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:20:17:59] Commandline is:
[2014-12-30:20:17:59] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:18:05] Relaunching with elevation
[2014-12-30:20:18:05] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air810b.tmp\adobe air installer.exe -ei
[2014-12-30:20:18:05] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:20:18:05] Commandline is: -stdio \\.\pipe\AIR_8448_0 -ei
[2014-12-30:20:18:05] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:18:05] Starting silent runtime update. Updating runtime from version 1.5.3.9130 to version 15.0.0.356
[2014-12-30:20:18:05] Installing msi at c:\users\brody\appdata\local\temp\air810b.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:18:08] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:18:08] Rolling back install of c:\users\brody\appdata\local\temp\air810b.tmp\setup.msi
[2014-12-30:20:18:08] Rollback complete
[2014-12-30:20:18:08] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:18:08] Runtime Installer end with exit code 7
[2014-12-30:20:18:18] Runtime Installer end with exit code 7
[2014-12-30:20:18:27] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:18:27] Commandline is:
[2014-12-30:20:18:27] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:18:32] Relaunching with elevation
[2014-12-30:20:18:32] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airf6c6.tmp\adobe air installer.exe -ei
[2014-12-30:20:18:32] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:18:32] Commandline is: -stdio \\.\pipe\AIR_11028_0 -ei
[2014-12-30:20:18:32] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:18:32] Starting silent runtime update. Updating runtime from version 1.5.3.9130 to version 15.0.0.356
[2014-12-30:20:18:32] Installing msi at c:\users\brody\appdata\local\temp\airf6c6.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:18:33] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:18:33] Rolling back install of c:\users\brody\appdata\local\temp\airf6c6.tmp\setup.msi
[2014-12-30:20:18:33] Rollback complete
[2014-12-30:20:18:33] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:18:33] Runtime Installer end with exit code 7
[2014-12-30:20:18:40] Runtime Installer end with exit code 7
[2014-12-30:20:19:15] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:19:15] Commandline is:
[2014-12-30:20:19:15] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:19:18] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:19:18] Commandline is:
[2014-12-30:20:19:18] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:19:21] Runtime Installer end with exit code 6
[2014-12-30:20:19:26] Relaunching with elevation
[2014-12-30:20:19:26] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airb498.tmp\adobe air installer.exe -ei
[2014-12-30:20:19:26] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:19:26] Commandline is: -stdio \\.\pipe\AIR_11420_0 -ei
[2014-12-30:20:19:26] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:19:26] Starting silent runtime update. Updating runtime from version 1.5.3.9130 to version 15.0.0.356
[2014-12-30:20:19:26] Installing msi at c:\users\brody\appdata\local\temp\airb498.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:19:27] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:19:27] Rolling back install of c:\users\brody\appdata\local\temp\airb498.tmp\setup.msi
[2014-12-30:20:19:27] Rollback complete
[2014-12-30:20:19:27] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:19:27] Runtime Installer end with exit code 7
[2014-12-30:20:19:48] Runtime Installer end with exit code 7
[2014-12-30:20:19:56] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:19:56] Commandline is:
[2014-12-30:20:19:56] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:19:59] Relaunching with elevation
[2014-12-30:20:19:59] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air524d.tmp\adobe air installer.exe -ei
[2014-12-30:20:19:59] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:19:59] Commandline is: -stdio \\.\pipe\AIR_916_0 -ei
[2014-12-30:20:19:59] Installed runtime (1.5.3.9130) located at C:\Program Files (x86)\Common Files\Adobe AIR
[2014-12-30:20:19:59] Starting silent runtime update. Updating runtime from version 1.5.3.9130 to version 15.0.0.356
[2014-12-30:20:19:59] Installing msi at c:\users\brody\appdata\local\temp\air524d.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:20:00] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:00] Rolling back install of c:\users\brody\appdata\local\temp\air524d.tmp\setup.msi
[2014-12-30:20:20:00] Rollback complete
[2014-12-30:20:20:00] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:00] Runtime Installer end with exit code 7
[2014-12-30:20:20:07] Runtime Installer end with exit code 7
[2014-12-30:20:20:39] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:20:39] Commandline is:
[2014-12-30:20:20:39] No installed runtime detected
[2014-12-30:20:20:41] Relaunching with elevation
[2014-12-30:20:20:41] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airfc80.tmp\adobe air installer.exe -ei
[2014-12-30:20:20:41] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:20:41] Commandline is: -stdio \\.\pipe\AIR_12540_0 -ei
[2014-12-30:20:20:41] No installed runtime detected
[2014-12-30:20:20:41] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:20:20:42] Installing msi at c:\users\brody\appdata\local\temp\airfc80.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:20:43] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:43] Rolling back install of c:\users\brody\appdata\local\temp\airfc80.tmp\setup.msi
[2014-12-30:20:20:43] Rollback complete
[2014-12-30:20:20:43] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:43] Runtime Installer end with exit code 7
[2014-12-30:20:20:49] Runtime Installer end with exit code 7
[2014-12-30:20:20:53] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:20:53] Commandline is:
[2014-12-30:20:20:53] No installed runtime detected
[2014-12-30:20:20:58] Relaunching with elevation
[2014-12-30:20:20:58] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air33c6.tmp\adobe air installer.exe -ei
[2014-12-30:20:20:58] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:20:58] Commandline is: -stdio \\.\pipe\AIR_10044_0 -ei
[2014-12-30:20:20:58] No installed runtime detected
[2014-12-30:20:20:58] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:20:20:58] Installing msi at c:\users\brody\appdata\local\temp\air33c6.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:20:59] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:59] Rolling back install of c:\users\brody\appdata\local\temp\air33c6.tmp\setup.msi
[2014-12-30:20:20:59] Rollback complete
[2014-12-30:20:20:59] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:20:59] Runtime Installer end with exit code 7
[2014-12-30:20:21:17] Runtime Installer end with exit code 7
[2014-12-30:20:28:20] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:20:28:20] Commandline is:
[2014-12-30:20:28:20] No installed runtime detected
[2014-12-30:20:28:22] Relaunching with elevation
[2014-12-30:20:28:22] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air344.tmp\adobe air installer.exe -ei
[2014-12-30:20:28:22] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:20:28:22] Commandline is: -stdio \\.\pipe\AIR_17624_0 -ei
[2014-12-30:20:28:22] No installed runtime detected
[2014-12-30:20:28:22] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:20:28:22] Installing msi at c:\users\brody\appdata\local\temp\air344.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:28:23] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:28:23] Rolling back install of c:\users\brody\appdata\local\temp\air344.tmp\setup.msi
[2014-12-30:20:28:23] Rollback complete
[2014-12-30:20:28:23] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:28:23] Runtime Installer end with exit code 7
[2014-12-30:20:28:28] Runtime Installer end with exit code 7
[2014-12-30:20:28:36] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:28:36] Commandline is:
[2014-12-30:20:28:36] No installed runtime detected
[2014-12-30:20:28:38] Relaunching with elevation
[2014-12-30:20:28:38] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air436f.tmp\adobe air installer.exe -ei
[2014-12-30:20:28:39] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:20:28:39] Commandline is: -stdio \\.\pipe\AIR_19160_0 -ei
[2014-12-30:20:28:39] No installed runtime detected
[2014-12-30:20:28:39] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:20:28:39] Installing msi at c:\users\brody\appdata\local\temp\air436f.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:20:28:39] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:28:39] Rolling back install of c:\users\brody\appdata\local\temp\air436f.tmp\setup.msi
[2014-12-30:20:28:39] Rollback complete
[2014-12-30:20:28:39] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:20:28:39] Runtime Installer end with exit code 7
[2014-12-30:20:28:41] Runtime Installer end with exit code 7
[2014-12-30:21:01:10] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:21:01:10] Commandline is:
[2014-12-30:21:01:10] No installed runtime detected
[2014-12-30:21:01:12] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:21:01:12] Commandline is:
[2014-12-30:21:01:12] No installed runtime detected
[2014-12-30:21:01:12] Relaunching with elevation
[2014-12-30:21:01:12] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air11c6.tmp\adobe air installer.exe -ei
[2014-12-30:21:01:12] Commandline is: -stdio \\.\pipe\AIR_25440_0 -ei
[2014-12-30:21:01:12] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:21:01:12] Installing msi at c:\users\brody\appdata\local\temp\air11c6.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:21:01:14] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:01:14] Rolling back install of c:\users\brody\appdata\local\temp\air11c6.tmp\setup.msi
[2014-12-30:21:01:14] Rollback complete
[2014-12-30:21:01:14] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:01:14] Runtime Installer end with exit code 7
[2014-12-30:21:01:14] Runtime Installer end with exit code 6
[2014-12-30:21:01:16] Runtime Installer end with exit code 7
[2014-12-30:21:01:57] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:21:01:57] Commandline is:
[2014-12-30:21:01:57] No installed runtime detected
[2014-12-30:21:02:04] Relaunching with elevation
[2014-12-30:21:02:04] Launching subprocess with commandline c:\users\brody\appdata\local\temp\aircb44.tmp\adobe air installer.exe -ei
[2014-12-30:21:02:04] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:21:02:04] Commandline is: -stdio \\.\pipe\AIR_1920_0 -ei
[2014-12-30:21:02:04] No installed runtime detected
[2014-12-30:21:02:04] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:21:02:04] Installing msi at c:\users\brody\appdata\local\temp\aircb44.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:21:02:05] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:02:05] Rolling back install of c:\users\brody\appdata\local\temp\aircb44.tmp\setup.msi
[2014-12-30:21:02:05] Rollback complete
[2014-12-30:21:02:05] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:02:05] Runtime Installer end with exit code 7
[2014-12-30:21:02:09] Relaunching with elevation
[2014-12-30:21:02:09] Launching subprocess with commandline c:\users\brody\appdata\local\temp\aire6fe.tmp\adobe air installer.exe -ei
[2014-12-30:21:02:09] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:21:02:09] Commandline is: -stdio \\.\pipe\AIR_6912_0 -ei
[2014-12-30:21:02:09] No installed runtime detected
[2014-12-30:21:02:09] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:21:02:09] Installing msi at c:\users\brody\appdata\local\temp\aire6fe.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:21:02:10] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:02:10] Rolling back install of c:\users\brody\appdata\local\temp\aire6fe.tmp\setup.msi
[2014-12-30:21:02:10] Rollback complete
[2014-12-30:21:02:10] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:21:02:10] Runtime Installer end with exit code 7
[2014-12-30:21:02:11] Runtime Installer end with exit code 7
[2014-12-30:21:02:12] Runtime Installer end with exit code 7
[2014-12-30:22:14:26] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:22:14:26] Commandline is:
[2014-12-30:22:14:26] No installed runtime detected
[2014-12-30:22:14:28] Relaunching with elevation
[2014-12-30:22:14:28] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airf9e8.tmp\adobe air installer.exe -ei
[2014-12-30:22:14:28] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-30:22:14:28] Commandline is: -stdio \\.\pipe\AIR_1380_0 -ei
[2014-12-30:22:14:28] No installed runtime detected
[2014-12-30:22:14:28] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:22:14:28] Installing msi at c:\users\brody\appdata\local\temp\airf9e8.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:22:14:32] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:14:32] Rolling back install of c:\users\brody\appdata\local\temp\airf9e8.tmp\setup.msi
[2014-12-30:22:14:32] Rollback complete
[2014-12-30:22:14:32] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:14:32] Runtime Installer end with exit code 7
[2014-12-30:22:14:36] Runtime Installer end with exit code 7
[2014-12-30:22:14:45] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:22:14:45] Commandline is:
[2014-12-30:22:14:45] No installed runtime detected
[2014-12-30:22:14:48] Relaunching with elevation
[2014-12-30:22:14:48] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air4347.tmp\adobe air installer.exe -ei
[2014-12-30:22:14:48] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:22:14:48] Commandline is: -stdio \\.\pipe\AIR_3328_0 -ei
[2014-12-30:22:14:48] No installed runtime detected
[2014-12-30:22:14:48] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:22:14:49] Installing msi at c:\users\brody\appdata\local\temp\air4347.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:22:14:50] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:14:50] Rolling back install of c:\users\brody\appdata\local\temp\air4347.tmp\setup.msi
[2014-12-30:22:14:50] Rollback complete
[2014-12-30:22:14:50] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:14:50] Runtime Installer end with exit code 7
[2014-12-30:22:14:51] Runtime Installer end with exit code 7
[2014-12-30:22:25:48] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:22:25:48] Commandline is:
[2014-12-30:22:25:48] No installed runtime detected
[2014-12-30:22:25:52] Relaunching with elevation
[2014-12-30:22:25:52] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air68d0.tmp\adobe air installer.exe -ei
[2014-12-30:22:25:52] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-30:22:25:52] Commandline is: -stdio \\.\pipe\AIR_6048_0 -ei
[2014-12-30:22:25:52] No installed runtime detected
[2014-12-30:22:25:52] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-30:22:25:52] Installing msi at c:\users\brody\appdata\local\temp\air68d0.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-30:22:25:53] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:25:53] Rolling back install of c:\users\brody\appdata\local\temp\air68d0.tmp\setup.msi
[2014-12-30:22:25:53] Rollback complete
[2014-12-30:22:25:53] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-30:22:25:53] Runtime Installer end with exit code 7
[2014-12-30:22:25:55] Runtime Installer end with exit code 7
[2014-12-31:10:31:13] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-31:10:31:13] Commandline is:
[2014-12-31:10:31:13] No installed runtime detected
[2014-12-31:10:31:15] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-31:10:31:15] Commandline is:
[2014-12-31:10:31:15] No installed runtime detected
[2014-12-31:10:31:19] Runtime Installer end with exit code 6
[2014-12-31:10:31:20] Relaunching with elevation
[2014-12-31:10:31:20] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air8bc9.tmp\adobe air installer.exe -ei
[2014-12-31:10:31:20] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-31:10:31:20] Commandline is: -stdio \\.\pipe\AIR_26988_0 -ei
[2014-12-31:10:31:20] No installed runtime detected
[2014-12-31:10:31:20] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-31:10:31:20] Installing msi at c:\users\brody\appdata\local\temp\air8bc9.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-31:10:31:21] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:31:21] Rolling back install of c:\users\brody\appdata\local\temp\air8bc9.tmp\setup.msi
[2014-12-31:10:31:21] Rollback complete
[2014-12-31:10:31:21] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:31:21] Runtime Installer end with exit code 7
[2014-12-31:10:31:25] Runtime Installer end with exit code 7
[2014-12-31:10:31:27] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:10:31:27] Commandline is:
[2014-12-31:10:31:27] No installed runtime detected
[2014-12-31:10:31:30] Relaunching with elevation
[2014-12-31:10:31:30] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airbff2.tmp\adobe air installer.exe -ei
[2014-12-31:10:31:30] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:10:31:30] Commandline is: -stdio \\.\pipe\AIR_25396_0 -ei
[2014-12-31:10:31:30] No installed runtime detected
[2014-12-31:10:31:30] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-31:10:31:30] Installing msi at c:\users\brody\appdata\local\temp\airbff2.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-31:10:31:31] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:31:31] Rolling back install of c:\users\brody\appdata\local\temp\airbff2.tmp\setup.msi
[2014-12-31:10:31:31] Rollback complete
[2014-12-31:10:31:31] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:31:31] Runtime Installer end with exit code 7
[2014-12-31:10:31:33] Runtime Installer end with exit code 7
[2014-12-31:10:37:56] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-31:10:37:56] Commandline is:
[2014-12-31:10:37:56] No installed runtime detected
[2014-12-31:10:40:40] Relaunching with elevation
[2014-12-31:10:40:40] Launching subprocess with commandline c:\users\brody\appdata\local\temp\airaec3.tmp\adobe air installer.exe -ei
[2014-12-31:10:40:40] Runtime Installer begin with version 15.0.0.356 on Windows 7 x86
[2014-12-31:10:40:40] Commandline is: -stdio \\.\pipe\AIR_32056_0 -ei
[2014-12-31:10:40:40] No installed runtime detected
[2014-12-31:10:40:40] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-31:10:40:40] Installing msi at c:\users\brody\appdata\local\temp\airaec3.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-31:10:40:41] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:40:41] Rolling back install of c:\users\brody\appdata\local\temp\airaec3.tmp\setup.msi
[2014-12-31:10:40:41] Rollback complete
[2014-12-31:10:40:41] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:10:40:41] Runtime Installer end with exit code 7
[2014-12-31:10:40:45] Runtime Installer end with exit code 7
[2014-12-31:14:31:51] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:14:31:51] Commandline is:
[2014-12-31:14:31:51] No installed runtime detected
[2014-12-31:14:31:54] Relaunching with elevation
[2014-12-31:14:31:54] Launching subprocess with commandline c:\users\brody\appdata\local\temp\aird9be.tmp\adobe air installer.exe -ei
[2014-12-31:14:31:54] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:14:31:54] Commandline is: -stdio \\.\pipe\AIR_23740_0 -ei
[2014-12-31:14:31:54] No installed runtime detected
[2014-12-31:14:31:54] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-31:14:31:55] Installing msi at c:\users\brody\appdata\local\temp\aird9be.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-31:14:31:55] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:14:31:55] Rolling back install of c:\users\brody\appdata\local\temp\aird9be.tmp\setup.msi
[2014-12-31:14:31:55] Rollback complete
[2014-12-31:14:31:55] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:14:31:55] Runtime Installer end with exit code 7
[2014-12-31:15:04:55] Runtime Installer end with exit code 7
[2014-12-31:22:01:34] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:22:01:34] Commandline is:
[2014-12-31:22:01:34] No installed runtime detected
[2014-12-31:22:01:36] Relaunching with elevation
[2014-12-31:22:01:36] Launching subprocess with commandline c:\users\brody\appdata\local\temp\air8ffa.tmp\adobe air installer.exe -ei
[2014-12-31:22:01:36] Runtime Installer begin with version 15.0.0.356 on Windows Vista x86
[2014-12-31:22:01:36] Commandline is: -stdio \\.\pipe\AIR_5172_0 -ei
[2014-12-31:22:01:36] No installed runtime detected
[2014-12-31:22:01:36] Starting silent runtime install. Installing runtime version 15.0.0.356
[2014-12-31:22:01:37] Installing msi at c:\users\brody\appdata\local\temp\air8ffa.tmp\setup.msi with guid {7BBAEC47-1CC0-4CB8-ADB4-531B78DBD1DD}
[2014-12-31:22:01:37] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:22:01:37] Rolling back install of c:\users\brody\appdata\local\temp\air8ffa.tmp\setup.msi
[2014-12-31:22:01:37] Rollback complete
[2014-12-31:22:01:37] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2014-12-31:22:01:37] Runtime Installer end with exit code 7
[2014-12-31:22:01:42] Runtime Installer end with exit code 7
You appear to have the same problem that I have....on my Windows 8.1 system an "install msi" failed in the logfile with text "1603". The installer reported "an error occurred, contact your system administrator".
Does anybody know what this error means or does anybody have any information on the contents of the Adobe Air log file?
You may want to try this user's suggestion:
Windows 8.1 control program Adobe Air uninstall fails with "error occurred, contact administrator"
