Highlighted
AIR does not read external microphone when recording
Explorer ,
May 02, 2017
On iOS devices running iOS 10.x, AIR does not always detect external microphones connected via Lightning connector. AIR will always use the Lightning microphone when connected to Flash Media Server using a NetStream and broadcasting over RTMP. However, AIR will not detect or use the Lightning microphone when recording audio locally, unless the microphone is plugged in after the user starts recording.
In other words, if you plug in a Lightning microphone and then run
microphone.addEventListener(SampleDataEvent.SAMPLE_DATA, microphone_sampleDataEventHandler);
AIR will not use the Lightning microphone. However, if you run
and then plug in the microphone while the app is already recording, AIR will use the microphone.
This bug is preventing us from releasing the next version of our app. Are there any better workarounds that don't require the user to wait until after they've started recording to plug in the mic?
Tested using AIR 23 and 24.
See Tracker
TOPICS
Performance issues
166
Likes
Community Guidelines
Explorer ,
May 02, 2017
See Tracker
TOPICS
Performance issues
167
Likes
May 02, 2017 0
Have something to add?
Join the conversation
