Highlighted
Do Flash (pro CS6) apps published for AIR 13 for android run on Android devices with older AIR ?
Community Beginner ,
Apr 14, 2014
Peace every one
I'm wondering.. if I publish my game (made using Flash Pro CS6) for Android AIR 13,will it run on android devices with
older version of AIR?
and if they do, will the performance of my game be affected?
or if they don't, will they be asked to update to AIR 13?
PS:some phones I tested my app on,(app was publshed to AIR 3.2) ,couldn't handle some features in the app
thank you soooo much for the great help.
Adobe Community Professional
Correct answer by Colin Holgate | Adobe Community Professional
The later versions of AIR always have a captive runtime. That means that if you publish with AIR 4 or AIR 13, that’s the version your app will use. It won’t matter if the user already has the AIR 3 runtime installed, it won’t get used.
TOPICS
Development
182
Likes
Community Guidelines
Apr 14, 2014
Peace every one
TOPICS
Development
183
Likes
Apr 14, 2014 0
Apr 14, 2014
Likes
Reply
Loading...
Apr 14, 2014 0
