In AIR 28, there was an issue with an extra padding being present at the top of a StageWebView. Adding "viewport-fit=cover" in the viewport meta tag solved the issue though (as explained here: Air 28 ios11 StageWebView unexpected padding at the top )
In AIR 29 beta, I saw in the release notes this issue has been fixed. However, it seems to have introduced another issue. Indeed, on iOS 11 at least, now the StageWebView viewport Y value is offset a few pixels up. For example, if I tell the viewport to be (0, 40, 640, 900), the StageWebView is actually located around (0, 8) and not (0, 40) as expected. This issue happens on iOS 11, not on Windows or Android. With AIR 28, it works fine (at least if I set the viewport tag to "viewport-fit=cover")
Thank you!
Thanks for reporting this issue. We're working on it and we'll keep you posted.
Pravishti | Adobe AIR Engineering
Ha sorry, totally missed that one
I'm a bit in advance so I have to make the hard work for you 😉
We've fixed this issue. Can you please check once with latest AIR 29 from Download Adobe AIR SDK​ and let us know if you still face problems.
I just tested, and it seems to work fine now. Thank you guys for the great job, as always!
