Highlighted
Starling can not work when I use air 18 SDK and etc2 format texture.
May 05, 2015
Thanks to the team of developing air sdk.
Problem Description:
After updated my air sdk to 18.0.0.109 and rebuild my texture used etc2 format, I meet an error "Invalid ATF format" from starling.
The code of Starling like this:
Starling-Framework/AtfData.as at master · Gamua/Starling-Framework · GitHub
  var format:uint = data.readUnsignedByte();
  switch (format & 0x7f)
  case 0:
  case 1: mFormat = Context3DTextureFormat.BGRA; break;
  case 2:
  case 3: mFormat = Context3DTextureFormat.COMPRESSED; break;
  case 4:
  case 5: mFormat = "compressedAlpha"; break; // explicit string to stay compatible
  // with older versions
  default: throw new Error("Invalid ATF format");
When I use flash builder to debug it, I found the value of the format is 12 or 13,  but I do not know what is the type of Context3DTextureFormat can match the value.
And I do not know if there are other format values.
Maybe starling also need to update to new version. The old version can not support the new air sdk 18. But I  can not find new version from Staring team.
How can I fix this issue now? Please give me some suggestion, thank you for your help.
TOPICS
Air beta
539
Likes
Community Guidelines
May 05, 2015
  case 0:
  case 2:
  case 4:
TOPICS
Air beta
540
Likes
May 05, 2015 0
Adobe Employee ,
May 06, 2015
Could you please provide your sample project so that we can invsitagte more into this.
also , did you try using Context3DTextureFormat.COMPRESSED_ALPHA as one of the value in Format?
-Vivek
Likes
Reply
Loading...
May 06, 2015 0
May 06, 2015
Hi Vivek Negi,
Thank you for your reply.
I have used the Context3DTextureFormat.COMPRESSED_ALPHA to test my application. The value 13 is ok, but the value 12 still can not work. Do you know other value of format and other types of  Context3DTextureFormat?
I do not know if air 18 added some new types of Context3DTextureFormat.
Thank you.
Likes
Reply
Loading...
May 06, 2015 0
Adobe Employee ,
May 07, 2015
Could you please provide your project and device ,so that we can investigate more.
-Vivek
Likes
Reply
Loading...
May 07, 2015 0
