HELP! Lots of small issues i can not fix
Jan 07, 2020
Ok, So im studying Creative iMedia and need to create an animation in animate but no idea what i am doing! I have made the animate (there are errors)  but the first thing i need to do is resize it - please tell me theres an easy way to do this by simply rescaling everything?
Please help, this is driving me crazy!
TOPICS
Error, How to, Other
407
Likes
Reply
Community Guidelines
Jan 07, 2020
Scale Content should allow the content to resize along with the stage:
Likes
Reply
Jan 07, 2020
Likes
Reply
Bexs_Student AUTHOR LATEST
Jan 09, 2020
Thank you, thats worked.
My next problem is i can not group 2 objects. I have a parcel and a stamp. I have read that you just need to selct both and group but this doesnt work. It only highlights one object and 'group' is unhighlighted.
What do i need to do/change?
Likes
Reply
Jan 07, 2020
The Q key gives you the free transform tool and that should help. Make sure you hold shift when you use it so you keep your aspect ration.
Likes
Reply
