How do I connect two body parts
Community Beginner ,
Dec 18, 2019 Dec 18, 2019
How can I connect the head to the scorpion tail?
In the part where the scorpion jumps 360 degree, you can see that the connection between the head and the tail isn't good and looks a bit glichy, how can I fix this?
TOPICS
How to
141
Likes
Community Guidelines
Guide , Dec 18, 2019 Dec 18, 2019
Likes
Guide ,
Hi mate,
Check this out:
http://flash-powertools.com/character-rigging-for-flash-animation/
Nick – Character designer and animator, Flash user since 1998
Member of Flanimate Power Tools team – extensions for character animation – flash-powertools dot com
Likes
Dec 21, 2019 Dec 21, 2019
Thank you so much!
Likes
