CC Project works fine, when export some parts not saving in the rec of project.
Explorer
/t5/character-animator-discussions/cc-project-works-fine-when-export-some-parts-not-saving-in-the-rec-of-project/td-p/10369750
Feb 28, 2019
Feb 28, 2019
I have noticed a few times, when I save a scene in CC, and export it into PR, some parts of the projects from CC does not save (via triggers), but if you look at your project in CC, its loading fine. I have used PNG, Media player, and direct link, has anyone noticed this before??
Be kind and respectful, give credit to the original source of content, and search for duplicates before posting.
Learn more
LEGEND
/t5/character-animator-discussions/cc-project-works-fine-when-export-some-parts-not-saving-in-the-rec-of-project/m-p/10369751#M9525
Feb 28, 2019
Feb 28, 2019
Do you mean Animate CC or Character Animator? They are different products - I am wondering if you are in the wrong forum.
Learn more
jimmyw3876728
AUTHOR
Explorer
/t5/character-animator-discussions/cc-project-works-fine-when-export-some-parts-not-saving-in-the-rec-of-project/m-p/10369752#M9526
Mar 01, 2019
Mar 01, 2019
sorry, I mean 'Character Animator'
Learn more
LEGEND
/t5/character-animator-discussions/cc-project-works-fine-when-export-some-parts-not-saving-in-the-rec-of-project/m-p/10369753#M9527
Mar 01, 2019
Mar 01, 2019
Puppets have properties, and then takes (recordings can override them). But there is also the puppet default. I was wondering if you were changing it in different contexts without realizing it.
Learn more
