On our ERP system Workcube, we receive our pdf documents with Adobe ColdFusion. But the system has been running very slow or stalling for the last 2 weeks. What do you think is the problem.
Let me move this to the ColdFusion forum for you, which is the appropriate forum for your question.
The Using the Community forum is for help in using the Adobe Support Community forums, not for help with specific programs. Product questions should be posted in the associated product community.
This is hard to answer without more information. First, I'm going to assume you're talking about generating PDFs with ColdFusion. That is just a slow thing at the best of times, frankly. If you're using CF Standard, PDFs can only be generated one at a time if I recall correctly, so they bottleneck the entire system. If you're using CF Enterprise, this isn't true, but each PDF to be generated still takes a long time.
I'd recommend if possible that you look at generating PDFs in the background instead of having users wait on them, or generate them in advance before users ask for them - whatever, just don't wait until they ask for them.
Dave Watts, Eidolon LLC
Adding to what Dave said, it's not clear if you are saying just the pages serving the PDFs are slow, or if all CF pages are slow. That could be a useful clue, as there are different solutions to those different problems
And if somehow it WAS just the PDF pages, then it would help to know if those pages are using CFDOCUMENT or the newer (since CF11) CFHTMLTOPDF tag (or their script equivalent). The former creates the PDFs within the CF instance, while the latter creates them in another service, called the CF "add on" service.
And then assuming you are using CFDOCUMENT, I will note that sometimes its performance can be increased with use of an attribute (on CFDOCUMENT) called LocalURL="yes". I have a blog post with more about it.
Finally, it's hard to tell from your question if you are CF developer or Admin who maybe inherited this system, or perhaps you're even just a user. I'll add that there are available tools that could quickly and easily help you pinpoint where the trouble and slowness is.
If you're not at all experienced with CF then you may find the questions above only raise more questions. If you'd rather just have someone work with you to find and resolve the problem, some of us here (including Dave and myself) are consultants, and if you'd rather get the problem solved quickly than engage in lots of back and forth, that's an option. I list myself and other such consultants here.
Otherwise, let us know what you find and we'll see if we can help you resolve this.
Yüksel5CFA: we receive our pdf documents with Adobe ColdFusion.
How do you integrate ColdFusion with Workcube? What does ColdFusion actually do? The more details you share, the more useful the feedback you will get from the forum.
Yüksel5CFA: the system has been running very slow or stalling
It is unclear to me what you mean by system. Workcube? ColdFusion? A specific ColdFusion process? The collaboration between Workcube and ColdFusion?
