basic problem with UDF
Mar 15, 2016 Mar 15, 2016
I'm very frustrated calling a UDF, not getting the correct results
Here's the function, placed in a template named "basic_function.cfm"
<cffunction name="test" access="public" output="yes" returnType="string">
<cfreturn "Hello World">
</cffunction>
<cfoutput>#test#</cfoutput>
The output I get: cfbasic_function2ecfm687063398$funcTEST@70c49b0c
How can I get the string "Hello World"?
TOPICS
Getting started
343
Likes
Community Guidelines
Engaged , Mar 15, 2016 Mar 15, 2016
You are currently just try to output whatever "test" is.  Since test is a function you would get what you are seeing.  Since you actually want to execute the function you need to call it as a function.<cfoutput>#test()#</cfoutput>HTH,--Dave
Likes
Engaged ,
HTH,
--Dave
Likes
That does it!
Thanks, Dave.
Likes
