CF11 Cfwindow problem Script: http://sbs/CFIDE/scripts/ajax/ext/ext-all.js:18
I am having a problem with all my pages that include Cfwindow after upgrading to CF11. There is a long delay (15seconds) and then the message -
Unresponsive Script
A script on this page may be busy, or it may have stopped responding. You can stop the script now, open the script in the debugger, or let the script continue.
This happens also on the test page from CF11 documents cfwindow - ColdFusion, English documentation - Adobe Learning Resources
Apart from the delay, the page loads and works fine.
Is this a problem with with my installation following upgrade or a more general issue?
Regards
Richard
What brands are your Operating System and Web server?
IIS7 Windows Small Business Server 2008
Sorry, I had apparently missed this one. My test records show that I had run the published example, cfwindow - ColdFusion, English documentation - Adobe Learning Resources , without any problems. I did so on Windows 7, Coldfusion 11, and Tomcat (built-in CF web server).
The file is Javascript. So it is meant for the browser. I therefore think you should verify whether the delay occurs with all the major browsers.
