ColdFusion11 Mobile - Datasource wont work the same for WEB and cfclient
Nov 19, 2015 Nov 19, 2015
I have an oracle data source which works fine in a web app but wont work if I write a cfquery inside a cfclient. I would like to know what the problem is or is it a bug.
index.cfm:
   <div id="actual_1"></div>
  <cfclientsettings  enableDeviceAPI = "false"  detectDevice = "false" >
  <cfclient>
   <cftry>
    <cfinvoke component="querydb" method="getDbdetails" returnvariable="variables.ServerForms"> </cfinvoke>
         <cfset document.getElementById("actual_1").innerHTML+=variables.ServerForms>
    <!---<form action="listcsar.cfm" method="post">
     <input type="submit" value="View my CSAR">
    </form>--->
    <cfcatch>
     <cfset document.getElementById("actual_1").innerHTML+= cfcatch.message & "<BR>">
    </cfcatch>
    </cftry>
    <cfset document.getElementById("actual_1").innerHTML+="DONE" & "<BR>">
  </cfclient>
QueryDB.cfc:
<cfcomponent >
<cffunction name="getDbdetails" access="remote"  returntype="numeric" >
     <cfquery name="tst" datasource="DEVTRY1" result="rr1">
    SELECT count(*) as counts FROM SECURITY.REQS
   </cfquery>
  <cfreturn tst.recordcount>
</cffunction>
</cfcomponent>
149
Likes
Community Guidelines
Engaged ,
Nov 20, 2015 Nov 20, 2015
Can you define "Won't work".  Are you getting an error message or something else that you can share?
--Dave
Likes
Dave, I get a error message - Cannot read property 'variables' of null. Its basically unable to connect to the same database.
I Write a query without CFCLIENT for the same DB it works but it fails if I write it inside CFCLIENT.
Likes
