Connection errors using http://localhost:8500/CFIDE/index.cfm
Explorer ,
Oct 01, 2015 Oct 01, 2015
So I thought I was having firewall (norton 360) issues but tech support fixed the firewall to allow me to connect to the cf administrator.
That effort failed, so I contacted my IP (xFinity) tech support folks and he turned their firewall off...and I still cannot connect.
If I cannot connect to the administrator, then I won't connect to anything I do in the report builder.
I've got to demo the report builder on the 2nd of October...staying up all night is my only option. So if you know, please do contact me!
Would anyone have a fix or an explanation of WT...is going on?
kevin@mesllc.net
995
Likes
Community Guidelines
Adobe Community Professional , Oct 02, 2015 Oct 02, 2015
The Coldfusion Administrator is normally athttp://localhost:8500/CFIDE/administrator/index.cfm
Likes
Likes
Explorer ,
Oct 09, 2015 Oct 09, 2015
Yeah, last night I took my work laptop home (xFinity Internet) and used 127.0.0.1/CFIDE/administrator/index.cfm! Worked as expected, then I tried it on my own laptop and I got the same error. So I'll rebuild the CF file installation and see if that helps.
Likes
