Could you please help on create Screct using cryto.hmac method in coldfusion
Nov 11, 2020 Nov 11, 2020
Please find below snippet , we have to convert to Coldfusion tags ,any one help me.
<script type="text/javascript">
var epochTime = "1605070736";
var Digest = computeDigest();
function computeDigest()
var hmac = Crypto.HMAC(Crypto.SHA256, epochTime, "1308302020102915214099263166", { asBytes: true });
var base64String = Crypto.util.bytesToBase64(Crypto.HMAC(Crypto.SHA256, epochTime, "AKI1308302020102915214099263166", { asBytes: true }));
return base64String;
</script>
51
Likes
Community Guidelines
Nov 12, 2020 Nov 12, 2020
ColdFusion code runs on the server. Your code is Javascript. Hence it is meant to run on the browser.
If you wish to run Crypto on ColdFusion then you should:
1) Import the Crypto Java library or classes into ColdFusion;
2) Also import any other third-party libraries that Crypto depends on.
Likes
