I have a question about coldfusion. By Mistake I delete my project from file system, my question is any way I can rollback my project. I am using Coldfusion builer 3.
Only hope is a backup or if you use version control. You would restore from that. Unless CF B puts what it deletes in the recycle bin. Otherwise, its no different to deleting a file normally.
The only other option that I can think of (and haxtbh‌ does bring up good points) is if you already have an undelete application on the system. If so, you can use that to find the files and restore them.
HOWEVER: If you do not already have one installed, DO NOT INSTALL ONE. This could overwrite the files you are trying to recover.
HTH,
^_^
