Hi there,
I am using CF2018 update 4 and flash player 32.0.0.223. I have a cfgrid populated from a query. One of the columns contain single percision floating point values between 2 and 60, usualy up to 5 significant figures. For example, a value of 7.2 appers as 7.19999980926514 in the flash grid, but appear as 7.2 in html and java grid.
I tried setting a mask of 99.9999 for the column and it appears as 00.0000 for every row! Any other settings I can use to correct the display issue or is this a bug?
Can't use HTML grid until the fix for 4024128 is released so I am stuck with the java grid for the moment.
Thanks in advance.
Could you share your code?
The code is pretty simple with the screen shot showing the result:
<cfquery name="getData" datasource="datasource1">
select * from TestResult
</cfquery>
<cfdump var=#getData#>
<cfform name="users1" action="#actionURL#" method="post">
<cfgrid name="users" query="getData" selectmode="edit" height="400" width="850" format="flash">
</cfgrid>
<input type="submit" value="Commit Changes">
</cfform>
May have found a workaround. If I loop through the query and specify the values for each row, then the flash grid display the floating point value correctly.
<cfgrid name="users" selectmode="edit" height="400" width="850" format="flash">
<cfgridcolumn name="index">
<cfgridcolumn name="labresult">
<cfloop query=getData>
<cfgridrow data="#index#,#labResult#">
</cfloop>
</cfgrid>
</cfform>
