I have a serial number for CF Builder 3, which is an upgrade version. My computer totally died, so I bought a new computer and installed CFB 3. I input my CFB 3 serial number and for my Previous Serial Number, I entered my CFB2 serial number. Both are from my Account page here on adobe.com. The OK button is not activated when I enter my Previous Serial Number. I copy/pasted from my Account page and I have confirmed that I have no extra spaces in the serial numbers.
I do remember that I had an issue with CFB 3 last year, and that I had to get a new serial number. That might be why this isn't working.
I started a Support Chat, but was told that they don't support CFB through chat. Are there any other options other than paying for a support call??
Kathryn
Hi Kathryn,
We have sent you the license key. Please verify the same and close this thread.
Happy to help
Anit Kumar
Hi Kathryn,
We apologize for inconvenience caused.
ColdFusion Builder 2 & 3 both are definitely supported via Support chat. Can you share the serial number in a PM and I can check that for you?
Anit Kumar
Thanks! I just sent you a message with the Serial Numbers.
Thanks for the same. The license keys are legitimate. Can you let us know, the exact error you are getting?
Anit Kumar
Hi Anit,
That's the thing; I am not getting an error. I put in the CF Builder 3 Serial Number, then put the CFB 2 serial number in the Previous Serial Number box, but the OK button doesn't activate.
Edit: I have removed the license key screenshot,
Anit Kumar
Hi Kathryn,
This seems like a licensing issue. Let me see, what can be done here.
Anit Kumar
HI Anit,
I got your message and tried to reply directly to it, but the message got kicked back with an error.
Yes, your idea sounds great. Thanks so much.
Kathryn
No problems at all.
Could you please send an email to cf.install@adobe.com referencing this thread and mentioning the license key in the email.
We will get that processed.
Anit Kumar
Hi Kathryn,
Happy to help
Anit Kumar
Thanks for all your help!
I have recently emailed the same issue with new serial IDs not working for CF Builder 2016 to support at: cf.install@adobe.com
Can someone please get back to me?
Ben
We just responded to your email.
Anit Kumar
Thanks Anit yes I got Priyank's response, waiting for final email with serial. I appreciate the prompt response! Great support!
Ben
Hello ,
i have the same problem , already send a message to cf.install@adobe.com . but what is the standard procedure ? is there a link at adobe site ?
thanks
Hi Spiros,
Thank you for sending us an e-mail. We have shared the instructions to activate the ColdFusion Builder via email. Please let us know if you need any further assistance.
Vikram
