Help with finding fonts in struct
Community Beginner ,
Nov 30, 2018 Nov 30, 2018
Hi everyone - this is silly, I know, but...
I'm a designer who can code a bit, and I have issues with font management on my system (I have about 2,000-odd fonts).
so, Cleverdix here decides to quickly write his own ColdFusion font manager, easy peasy.  Import all the font families into a database, add my own delimiters (such as "oh yeah" and "Crap" and  'handwritten") so that when I look for a font, I can run a query, and find the fonts I'm looking for.  Heaven!  Got the database set up, works like a charm.
Except, of course, it does not, because coldfusion doe snot want to render the fonts.
Do a bit of digging, and I find this gem:
<cfset adminObj = createObject("Component", "cfide.adminapi.administrator")>
<cfset adminObj.login("password", "user")>
<cfset rtService = createObject("component", "cfide.adminapi.runtime")>
<cfset fonts = rtService.getFonts()>
Ta-dah! absolutely brilliant - I now have a struct with all my fonts...  within a struct residing in a struct residing in a struct...  4 nested structs, and now I'm as lost as a Polar Bear in Australia.
Questions:
How do I get the "second key" and the third key, etc, so that I can loop over them and insert them into my database?
with my limited knowledge, I can get the 1st struct key, which returns me "systemfonts" and "userfonts" - as useless as a snooker table on a canie.  I know what the hell that second key is, and the third one, so that I can list all the variables in a way that makes sense to me.
Basic desired outcome is a database that looks sort-of like this:
rowid | font family | font-face | postscript name | path
When I can import the family, face and postscript into my database, I'll be happy as an ant at a picnic.
thank you - thank you - I'll email you a sixpack for your effort.
289
Dec 01, 2018 Dec 01, 2018
Hi Jellyhead​,
Here's an idea:
<cfscript>
adminObj = createObject("Component", "cfide.adminapi.administrator");
adminObj.login("password", "user");
rtService = createObject("component", "cfide.adminapi.runtime");
fonts = rtService.getFonts();
/*writedump(fonts);*/
/* In the database, create a table named 'fonts', using SQL similar to the following (MySQL)*/
DROP TABLE IF EXISTS 'fonts';
CREATE TABLE 'fonts' (
  'id' int(11) NOT NULL AUTO_INCREMENT,
  'isSystemFont' tinyint(1) DEFAULT NULL,
  'familyName' varchar(100) DEFAULT NULL,
  'fontName' varchar(100) DEFAULT NULL,
  'description' varchar(100) DEFAULT NULL,
  'fontType' varchar(30) DEFAULT NULL,
  'location' varchar(100) DEFAULT NULL,
  'psname' varchar(100) DEFAULT NULL,
  PRIMARY KEY ('id')
/* Create an array corresponding to each column in the database table */
isSystemFont=[];
familyname=[];
fontname=[];
description=[];
fontType=[];
location=[];
psname=[];
rowNumber=1;
for (group in fonts) {
    for (famName in fonts[group]) {
        for (font in fonts[group][famName]) {
            for (fontProperty in fonts[group][famName][font]) {
                switch(fontProperty) {
                    case "description":
                    description[rowNumber]=fonts[group][famName][font][fontProperty];
                    break;
                    case "fonttype":
                    fonttype[rowNumber]=fonts[group][famName][font][fontProperty];
                    break;
                    case "location":
                    location[rowNumber]=fonts[group][famName][font][fontProperty];
                    break;
                    case "psname":
                    psname[rowNumber]=fonts[group][famName][font][fontProperty];
                    break;
            if (group is "SYSTEMFONTS") {
                isSystemFont[rowNumber]=1;
            } else {
                isSystemFont[rowNumber]=0;
            fontname[rowNumber]=font;
            familyname[rowNumber]=famName;
            rowNumber++;
/* Create the INSERT SQL string */
sql="insert into fonts (isSystemFont,
                        familyname,
                        fontname,
                        description,
                        fontType,
                        location,
                        psname) values ";
for (i=1; i <= arrayLen(description); i++) {
    if (i > 1) {
        sql=sql & ",";
    /* Replace \ with /, as / is an escape character for some database brands */
    location=replace(location,"\","/","all");
    sql=sql & "          (#isSystemFont#,'#familyname#','#fontname#','#description#','#fontType#','#location#','#psname#')";
/* Insert the data into the database table */
sqlParams={};
queryExecute(sql, sqlParams, {datasource="myDSN"});
</cfscript>
Votes
Dec 02, 2018 Dec 02, 2018
I've not had time to test it yet, but yes - this is exactly it - thanks!
Votes
Dec 04, 2018 Dec 04, 2018
Please read instead:
/* Replace \ with /, as \ is an escape character for some database brands */
Votes
Resources
Documentation
