Help with how cfhttpparam work.
Engaged ,
Jan 27, 2016 Jan 27, 2016
This is what it says on the API Basics | KnowledgeOwl site. But it seemed that for it to work, the full URL look something like this.
https://app.knowledgeowl.com/api/head/category/5697c6a632131cd740bd3123.json?_authbykey=56a7d8c51233...
So, this is my attempt in using cfhttpparam.
<cfhttp url="https://app.knowledgeowl.com/api/head/category/.json?" method="GET" >
  <cfhttpparam name="categoryID" value="c6a632131cd740bd3123">
  <cfhttpparam name="_authbykey" value="56a7d8c512331c4058361687">
  <cfhttpparam name="project_id" value="55c4ffd131231c527e294fe6">
</cfhttp>
Okay, so I got Error in custom script module error. Any suggestion is much appreciated.
207
Likes
Community Guidelines
Engaged , Jan 27, 2016 Jan 27, 2016
The url in the CFHTTP tag shouldn't end in a "?".   Also, you need the type="url" on the pram tags.
Likes
Advocate ,
You are missing the type="URL" parameter. I'm not sure if there is a default type or not but that is where I would start.
Likes
Engaged ,
Likes
Engaged ,
Thanks, guys! That works.
Likes
