help with sql insert
New Here
/t5/coldfusion-discussions/help-with-sql-insert/td-p/7363550
Jul 02, 2015
Jul 02, 2015
<cfset pcsDate= #CreateDate(form.Cyear, form.Cmonth, form.Cday)#> | ||
<cfquery datasource="pcs" username="manpcs" password="Charle54!"> |
INSERT INTO client | |
First_Name, | |
Last_Name, | |
Phone, | |
Email, | |
Rank, | |
CSFirst_Name, | |
CSLast_Name, | |
CSPhone, | |
CSEmail, | |
CSRank, | |
Address, | |
City, | |
State, | |
Postal, | |
CDuty_Station, | |
FDuty_Station, | |
PCSDate, | |
Children, | |
Owner) | |
VALUES | |
(#form.CFirst_name#, | |
#form.CLast_name#, | |
#form.CMobil#, | |
#form.CEmail#, | |
#form.CRank#, | |
#form.CSFirst_Name#, | |
#form.CSLast_Name#, | |
#form.CSMobil#, | |
#form.CSEmail#, | |
#form.CSRank#, | |
#form.CAddress#, | |
#form.CCity#, | |
#form.CState#, | |
#form.CPostal#, | |
#form.CDuty_Station#, | |
#form.CFuture_Duty_Station#, | |
#DateFormat(PCSDate, "mmmm d, yyyy")#, | |
#form.CChildren#, | |
#form.COwner#) |
</cfquery>
Error Executing Database Query. | ||||||||
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '3, 2017, 3, 2)' at line 39 | ||||||||
The error occurred in D:/home/manpcs.com/wwwroot/Clients/insert_action.cfm: line 46 | ||||||||
44 : #DateFormat(PCSDate, "mmmm d, yyyy")#, 45 : #form.CChildren#, 46 : #form.COwner#) 47 : </cfquery> 48 : | ||||||||
Any help is appreciated
TOPICS
Getting started
Be kind and respectful, give credit to the original source of content, and search for duplicates before posting.
Learn more
/t5/coldfusion-discussions/help-with-sql-insert/m-p/7363551#M169048
Jul 05, 2015
Jul 05, 2015
Two things:
1) DateFormat(PCSDate, "mmmm d, yyyy") is in fact a string. The error arises because you attempted to insert it into a date column. It introduces an extra comma, which breaks your query. Format the database date column, not the input value.
2) Use cfqueryparam for inserting form variables into the database. In fact, that will enable you to just insert the date as
<cfqueryparam value = "#pcsDate#" cfsqltype = 'cf_sql_date'>.
Learn more
