how do I save a variable, using AJAX, to a mySQL database using Coldfusion?
Sep 20, 2015 Sep 20, 2015
I have a jquery script that picks a background color from an image using AJAX. I would like to save the variable, var rgba=e.rgba() to a MySQL databse. The individual who created the script said to use: $.post("color.php",{rgba:reba}); to save to a database with AJAX. How do I save the var rgba using coldfusion to do the CF side?
The script:
<script>
;(function($){
    $.fn.canvasify = function(f){ // faster than dynamically converting a pixel at a time
        return this.map(function(){
            if (this.nodeName=="IMG"){
                var canvas=$('<canvas>')
                this.src = this.src // IE fix
                $(this).one('load',function(){
                    canvas.attr({width:this.width,height:this.height})
                    canvas[0].getContext('2d').drawImage(this,0,0,this.width,this.height)
                    $(this).replaceWith(canvas)
                return canvas[0]
            }else{
                return this
    function Rgba(rgba){
        this.rgba = rgba
        this.toString = function(){ return "rgba("+Array.prototype.join.call(this.rgba,',')+")" }
    $.Event.prototype.rgba=function(){
        var x =  this.offsetX || (this.pageX - $(this.target).offset().left),
            y =  this.offsetY || (this.pageY - $(this.target).offset().top),
            nodeName = this.target.nodeName
        if (nodeName==="CANVAS")
            return new Rgba(this.target.getContext('2d').getImageData(x,y,1,1).data)
        else if (nodeName==="IMG"){
            var canvas=document.createElement("canvas")
            canvas.width=1
            canvas.height=1
            canvas.getContext('2d').drawImage(this.target,x,y,1,1,0,0,1,1)
            return new Rgba(canvas.getContext('2d').getImageData(0,0,1,1).data)
        } else return null
})(jQuery)
    $(function() {
        $("figure").append("<p class="rgba">")
        $('img').canvasify().click(demo)
    //    $('img').click(demo)
        function demo(e){
            var rgba=e.rgba(),
                figure = $(this).parent()
            figure.css('background-color',rgba).find("p").text(rgba)
    </script>
    <style>
    p.rgba {
        background:white;
        color:black;
        border:1px solid red;
        min-height:20px;
    </style>
TOPICS
Database access
1.1K
Likes
Community Guidelines
Adobe Community Professional , Oct 02, 2015 Oct 02, 2015
Here is some pseudocodeAJAX...$data = {rgba:$rgba,var1=$var1,var2=$var2, etc.};...var ajaxResponse = $.ajax({    type: "POST",    url: "../../dir/Settings.cfc?method=saveBGColor,    contentType: "application/json; charset=utf-8",    data: JSON.stringify($data),    etc.});Settings.cfc<cfcomponent>  <cffunction name="saveBGColor" access="remote">    <cfset requestBody = toString(getHttpRequestData().content)>    <!--- Double-check to make sure it's a JSON value. --->    <cfif isJSON(requestBody)> ...
Likes
AJAX
    type: "POST",
    etc.
Settings.cfc
<cfcomponent>
        <!--- Extract background colour from request body--->
        <!--- Save background colour to database --->
    </cfif>
  </cffunction>
</cfcomponent>
Likes
Oct 31, 2015 Oct 31, 2015
Sorry it has taken so long to get back. Your suggestion worked perfectly. Thank you
Likes
