IIS 10 Coldfusion 11 served website won't load default home page on IOS mobile devices
Community Beginner ,
Apr 27, 2017 Apr 27, 2017
Have a Windows 2016 server with IIS 10 running ColdFusion 11. Certain websites (with https://) won't load the default home page on iPhone and iPad only. The default home pages load great on all browsers on Windows 10, and even on a Mac in Safari and Chrome, but won't load on iPhone and iPad in either Safari or Chrome -- they just time out. If I put the name of the default page in the URL, it will load just fine on these IOS mobile devices, but if I just use the site's domain name, it will NOT load. IOS versions are up-to-date. If we set the default page to an html page it WILL load; if we set it to a cfm page it WILL NOT load.
So the FAILING situation is in loading default cfm page on iPhone or iPad.
I have come up with a workaround for this problem.
I created an index.html file containing:
<meta http-equiv="refresh" content="0;URL='https://domainname.com/index.cfm'" />
and made index.html the default page for the website.
I don't like it, but it seems to get things working on the iPad and iPhone.
Anyone have any suggestions?  Thanks!
2.5K
Likes
Community Guidelines
Apr 29, 2017 Apr 29, 2017
This problem does not occur with IIS 6 on an earlier server operating system.  Only with IIS 10 on Windows Server 2016.
Likes
Aug 14, 2017 Aug 14, 2017
We are experiencing this too. We have IIS 10 and ColdFusion 2016. Any solutions?
Likes
Advocate ,
Aug 17, 2017 Aug 17, 2017
I think this is related to this bug:
https://tracker.adobe.com/#/view/CF-4198446
Likes
Oct 03, 2017 Oct 03, 2017
This is apparently a bug in Safari version 9 and newer.  Affects ColdFusion running on Windows Server 2016, but also other applications (reported by other developers of ASP, ASP.net and NGINX.)
Detailed here:
http://www.giancarlogomez.com/2016/05/coldfusion-iis-10-http2-safari-bug.html
Temporary fix (disable http2 on Windows Server 2016 in the registry):
- Open the registry editor (regedit)
- Browse to Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HTTP\Parameters
- Enter 2 new DWORD Values EnableHttp2Cleartext and EnableHttp2Tls
- Set their values to 0
- Reboot
Reference:
https://www.youtube.com/watch?v=a__h2EkbCb4
https://medium.com/@jason.mcclellan/nginx-safari-http2-not-working-607a8333e67a
Likes
Nov 16, 2017 Nov 16, 2017
I believe this was resolved with iOS 11. We had this issue but after upgrading to iOS 11, I could no longer reproduce this issue.
Likes
Jun 05, 2018 Jun 05, 2018
We have worked with Microsoft and this issue has been fixed in the Windows update released by them. The update's key is: KB4093120.
It can be found on this link: https://www.catalog.update.microsoft.com/Search.aspx?q=2018-04
We have verified this fix at our end and everything seems to work fine. Please do let us know in case you find that the issue has not been fixed Microsoft in their update.
Thanks
Nikhil Siddhartha
Adobe ColdFusion
Likes
