Need help with ColdFusion 2016 Installation.
Community Beginner ,
Feb 17, 2018 Feb 17, 2018
We planned to upgrade our ColdFusion9 version to ColdFusion2016. During installation, at 76% the process is not at all moving further. I am breaking my head with this silly issue. Tried reinstalling by quieting the current installation but was no luck. And one more point, before reinstalling again i tried to uninstall but it was throwing a fatal application error: "This Application has Unexpectedly Quit.  Invocation of this Java Application has caused an Invocation TargetException".  Please help me. Any suggestions are accepted.
OS of the machine is Windows server 2008, 32-bit.
RAM 4GB.
Previous version of ColdFusion is ColdFusion9.
Note that i am following the Adobe ColdFusion (2016 release) Migration guide.
285
Likes
Community Guidelines
There will be a log file on your desktop, I think. I would recommend looking for the last entry in there. Also, make sure the account you're using is an administrator, even if you don't explicitly "run as admin".
I would really recommend going to a new 64-bit machine with 8+GB RAM.
Dave Watts, CTO, Fig Leaf Software
Likes
Thank you so much Dave for the suggestions/recommendations.
I kept the installation for couple of hours, and it got completed successfully. Didn't know how that happened. Somehow i got rid of that problem.
Thanks again for your quick reply.
Revati.
Likes
Feb 20, 2018 Feb 20, 2018
Hi Dave,
I need some information/suggestion on ColdFusion certification. I am a web developer and use ColdFusion 9. I am having 4 years of experience in ColdFusion 9 and recently I started using ColdFusion 2016 as well.
Now I am planning to do certification in ColdFusion. I really do not have any idea on these certification exams.    what
Could you please suggest me on the following---
  1. Which versions of ColdFusion ACE Exams are available?
  2. Which ColdFusion ACE Exam I can go for(based on my experience)?
  3. Can you please mention the cost of the Exam?
  4. Can you suggest me books/online materials required for the certification?
  5. Any blogs for ColdFusion certification?
Thank you in advance.
--Revati
Likes
Feb 21, 2018 Feb 21, 2018
Hi Dave,
--Revati
Likes
To the best of my knowledge, there is no longer an Adobe-authorized ColdFusion exam available.
Dave Watts, Fig Leaf Software
Likes
Feb 26, 2018 Feb 26, 2018
Thank you Dave for the info.
Likes
