Power bi and coldfusion
Nov 04, 2019 Nov 04, 2019
How can Power BI be integrated into a coldfusion application?
TOPICS
Connector
333
Likes
Community Guidelines
Adobe Community Professional , Nov 04, 2019 Nov 04, 2019
There is no built in integration, if that may be what you mean. And while asp.net offers an sdk to facilitate such integration, there is no such sdk for cfml. That said, the doc for that asp.net sdk (https://docs.microsoft.com/en-us/power-bi/developer/embed-sample-for-your-organization) shows that there is a rest api for powerbi (https://docs.microsoft.com/en-us/rest/api/power-bi/). And cf has built-in rest integration, so you should be able to do such integration that way. I'm not aware of ...
Likes
And cf has built-in rest integration, so you should be able to do such integration that way. I'm not aware of any resources showing such cf/power bi integration specifically.
Hope that helps.
/Charlie (server troubleshooter, carehart.org)
Likes
Nov 05, 2019 Nov 05, 2019
Nkechi, did this help?
Likes
Nov 06, 2019 Nov 06, 2019
Yes it did.
Thanks so much
Likes
Great to hear, and thanks for the update. I've gone ahead and marked it as the "answer", to help future readers.
Likes
