Problem installing coldfusion16 and C++ runtimeI
Contributor ,
Jun 19, 2017 Jun 19, 2017
I have coldfusion11 installed and working.
I want to install coldfusion16
when I run the install exe, it says preinstall check : Microsoft VC++ 2012 runtime
So I click "ok" to install.
At end , it says to run again the Install exe.
I do so.
And again, it comes on : preinstall check : Microsoft VC++ 2012 runtime
It always want to install  Microsoft VC++ 2012 runtime
nothing else.
Thanks for help.
Pierre.
TOPICS
Advanced techniques
643
Adobe Employee ,
Jun 20, 2017 Jun 20, 2017
Hi Pierre,
Could you please try installation Microsoft VC++ 2012 runtime manually using the below links:
Microsoft Visual C++ Redistributable 2012
Microsoft Visual C++ Redistributable 2012 - 32-bit (x86) Download
Microsoft Visual C++ Redistributable 2012 - 64-bit (x64) Download
Thank You,
Abhishek
Resources
