We use Amazon S3 for storing the majority of our products and the code is well established and has been working hundreds of times a day for well over 8 months, so it's very stable however today I've had loads and loads of problems with errors - Is anyone else seeing issues?
The code is very simple:
<cfset fileWrite("#baseS3Url#/#amazonFileName#", "#binFileData#")>
<cfset storeSetMetadata("#baseS3Url#/#amazonFileName#", { content_type="#setContentType(XML)#" })>
OR
<cfset fileWrite("#baseS3Url#/#amazonFileName##fileExtension#", "#binFileData#")>
<cfset storeSetMetadata("#baseS3Url#/#amazonFileName##fileExtension#", { content_type="#setContentType(fileExtension)#" })>
but is throwing the following stack trace
StackTrace: coldfusion.vfs.VFileOutputStream$VFSFileSystemException: Request Error. nullCould not close the output stream for file "s3://<cname>/0/0/1/1/3/4/5/1134503_SRBDG7FY8U.pdf"..
at coldfusion.vfs.VFileOutputStream.close(VFileOutputStream.java:81)
at coldfusion.tagext.io.FileUtils.writeFile(FileUtils.java:867)
at coldfusion.runtime.CFPage.FileWrite(CFPage.java:2918)
at coldfusion.runtime.CFPage.FileWrite(CFPage.java:2909)
at cfAmazonUtil2ecfc1396299930$funcWRITEFILETOAMAZON.runFunction(F:\CfGlobal\amazonWebServices\AmazonUtil.cfc:160)
at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472)
at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405)
at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368)
at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55)
at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321)
at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:220)
at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:491)
at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:337)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2360)
at cfListenerUtils2ecfc321451058$funcWRITEFILETOAMAZON.runFunction(F:\CfGlobal\util\ListenerUtils.cfc:758)
at coldfusion.runtime.CfJspPage._invokeUDF(CfJspPage.java:2582)
at cfListenerUtils2ecfc321451058$funcWRITEFILETOLOCALPLUSAMAZON.runFunction(F:\CfGlobal\util\ListenerUtils.cfc:812)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2360).....
Caused by: org.apache.commons.vfs.FileSystemException: Could not close the output stream for file "s3://documents.etsosreports.co.uk/0/0/1/1/3/4/5/1134503_SRBDG7FY8U.pdf".
at org.apache.commons.vfs.provider.DefaultFileContent$FileContentOutputStream.close(DefaultFileContent.java:599)
at coldfusion.vfs.VFileOutputStream.close(VFileOutputStream.java:69)
... 52 more
Caused by: java.io.IOException: Request Error. null
at coldfusion.vfs.s3.S3OutputStream._close(S3OutputStream.java:145)
at coldfusion.vfs.s3.S3OutputStream.access$000(S3OutputStream.java:46)
at coldfusion.vfs.s3.S3OutputStream$1.run(S3OutputStream.java:108)
at java.security.AccessController.doPrivileged(Native Method)
at coldfusion.vfs.s3.S3OutputStream.close(S3OutputStream.java:103)
at java.io.FilterOutputStream.close(Unknown Source)
at org.apache.commons.vfs.util.MonitorOutputStream.close(MonitorOutputStream.java:53)
at org.apache.commons.vfs.provider.DefaultFileContent$FileContentOutputStream.close(DefaultFileContent.java:595)
... 53 more
TagContext:
[array]
1) [struct]
COLUMN: 0
LINE: 160
RAW_TRACE: at cfAmazonUtil2ecfc1396299930$funcWRITEFILETOAMAZON.runFunction(F:\CfGlobal\amazonWebServices\AmazonUtil.cfc:160)
TEMPLATE: F:\CfGlobal\amazonWebServices\AmazonUtil.cfc
TYPE: CFML
2) [struct]
COLUMN: 0
LINE: 758
RAW_TRACE: at cfListenerUtils2ecfc321451058$funcWRITEFILETOAMAZON.runFunction(F:\CfGlobal\util\ListenerUtils.cfc:758)
TEMPLATE: F:\CfGlobal\util\ListenerUtils.cfc
TYPE: CFML
3) [struct]
COLUMN: 0
LINE: 812
RAW_TRACE: at cfListenerUtils2ecfc321451058$funcWRITEFILETOLOCALPLUSAMAZON.runFunction(F:\CfGlobal\util\ListenerUtils.cfc:812)
TYPE: CFML
4) [struct]
COLUMN: 0
LINE: 84
RAW_TRACE: at cfDeliveryUsersBatch2ecfc1575326645$funcPROCESS.runFunction(F:\web\integration.etsos.co.uk\wwwroot\ScheduledTasks\deliveryUsers\DeliveryUsersBatch.cfc:84)
TEMPLATE: F:\web\integration.etsos.co.uk\wwwroot\ScheduledTasks\deliveryUsers\DeliveryUsersBatch.cfc
TYPE: CFML
5) [struct]
COLUMN: 0
LINE: 28
RAW_TRACE: at cfDeliveryUsers2ecfm1067211157$func_CFFUNCCFTHREAD_CFDELIVERYUSERS2ECFM10672111571.runFunction(F:\web\integration.etsos.co.uk\wwwroot\ScheduledTasks\deliveryUsers\DeliveryUsers.cfm:28)
TEMPLATE: F:\web\integration.etsos.co.uk\wwwroot\ScheduledTasks\deliveryUsers\DeliveryUsers.cfm
TYPE: CFML
Type: Application
msg: Request Error. nullCould not close the output stream for file "s3://documents.etsosreports.co.uk/0/0/1/1/3/4/5/1134503_SRBDG7FY8U.pdf".
This is still continuing today - I'm starting to think it has something to do with the 9.0.2 Hotfix patch 1 that was installed this weekend
Hello Jo, did you ever find an answer to this? I'm experiencing the same issue.
