Problem with CF2018 MultiSelect checkboxes and select passing an array rather than a list
Apr 23, 2021 Apr 23, 2021
I ran into a problem when applying the 11th update for CF2018 as the drive ran out of space, which corrupted the files and ended up having to uninstall and re-install on a separate drive in order to resolve the issue; however, now I am dealing with an odd quirk in that when a form with multiple checkboxes or multiple selections from a select lists is submitted -- I receive the variable as an array rather than a list, which causes issues when I attempt to pass that variable into a query via cfqueryparam.
Is there an option that can be adjusted to control this behavior?   My code has not changed and now gives an error about a complex type.   I would prefer to have the items submitted as a list or string, as otherwise, I have to go into my code in all these places to test if it's an array and then call ArrayTolist, which was never needed before the reinstall.
90
Yes, there is a solution. See my response to a similar question here:
https://community.adobe.com/t5/coldfusion/coldfusion-2018-update-11-error/m-p/11954596#M188253
There's a discussion there also how this is unexpected and undocumented in the update, and so unfortunate, but no longer unresolved for you, to slip in one more "un" there. 🙂
/Charlie (troubleshooter, carehart.org)
Votes
Apr 24, 2021 Apr 24, 2021
The gist of the discussion Charlie refers to: set sameFormFieldsAsArray to false.
Application.cfm
<cfapplication name="myApplication" sameFormFieldsAsArray="false">
Application.cfc
<cfcomponent >
  <cfset this.name = "myApplication">
  <cfset this.sameFormFieldsAsArray="false">
</cfcomponent >
Votes
Resources
Documentation
