So tired solving this problem, Help please
Jul 04, 2019 Jul 04, 2019
This is my table for messages
I'm trying to pull data from only mid no 1 and mid no 4, basically my goal is to get the last message from every sender
First i created a query to pull all the message for a user, in this case receiver id is 1
<cfquery name="messages_tb" datasource="appdb">
    SELECT * FROM messages
    WHERE receiver = <cfqueryparam value="1" cfsqltype="cf_sql_integer">
</cfquery>
then i created a list of every sender id
<cfset list.messages_tb_sender_uid = ValueList(messages_tb.sender)>
after that i did this
    SELECT MAX(mid) as last_id from messages
    WHERE sender IN ( <cfqueryparam value="#list.messages_tb_sender_uid#" cfsqltype="cf_sql_varchar" list="yes">)
    and receiver = <cfqueryparam value="1" cfsqltype="cf_sql_integer">
</cfquery>
<cfset list.messages_tb_last = ValueList(messages_tb.last_id)>
<cfoutput>
    #list.messages_tb_last#
</cfoutput>
The problem is im getting only 1 row, i dont wanna use loop or output query. Is there any way to just create a list of last mid of every sender ?
178
Likes
Community Guidelines
Adobe Community Professional , Jul 04, 2019 Jul 04, 2019
If that last valuelist has only 1, then the messages_tb query has only one record.   Do a cfdump of the query  to confirm. So this is not a cfml problem but a sql one.I would think you could do a simpler single select, whether with group by or subqueries, but a) I'd have to build out a test table to be sure my proposal was right and b) I'm on my phone.My guess would be that this could work:SELECT   sender, MAX(mid)FROM      messagesGROUP BY senderBut if not, it could help if you used querynew an...
Likes
FROM      messages
GROUP BY sender
But if not, it could help if you used querynew and related functions to create a simulated query result, against which folks could then try to do a qofq in cfml, and in cffiddle.org or trycf.com, even from a phone. (Sure, we could "just do it". I'm proposing how you could help us help you.)
It may also help to know what dbms/version you're using, as some problems are best solved using db-specific features--as long as you don't favor cross db compatibility over efficiency. For instance, windowing function if in more recent versions of sql server can do amazing things.
/Charlie (server troubleshooter, carehart.org)
Likes
Thank you soooo much, it works like a charm!
Thanks a ton man, You just made my year This problem was eating me alive ! not anymore
Likes
Jul 05, 2019 Jul 05, 2019
Very good to hear, and thanks for marking it as the answer.
Likes
