I face the problem with Vista.
Can we sue Adobe for not rectifying the error?
The Flash10a.ocx problem has caused problems for too many users.
You have only to search and you can find complaints everywhere.
Maybe someone out there is a very good lawyer.
We ought to force Adobe to take appropriate actions.
Why don't you rectify the error? Flash10a.ocx is old; uninstall it, then install the newest version, and all will be well.
You can download the uninstaller from http://www.adobe.com/go/tn_14157
I try that but no luck.. Help me please....
Don't you all need falsh 10c.ocx? the new flash player 10.0.32.18?
You tried what? Did you uninstall it?
What is your OS and browser?
What is your problem?
As suggested by Pat Willener, I uninstalled flash10 and then reinstalled the lastest flash10. I have no problems so far.
I have also disabled sleep mode which causes other problems.
I have the following files in this folder: C:\WINDOWS\system32\Macromed\Flash\
uninstall_activeX
SWFlash.ocx
install
FlashUtil10b
Flash10b.ocx
Flash10a - Copy.ocx
I think you should have the two files in blue in the above folder.
I am using vista. When I had the flash10 problem, I was using IE7. The problem was corrected for IE7. I am using IE8 now. No problems, so far.
I try to download it but it won't register when I did.....
Message was edited by: Angel-chan
