FM-14 (2017) does not show Help > Help Topics
Advocate ,
Mar 19, 2018
Dear all,
Although there is $home\HelpViewer.exe and $home\HelpCfg.ini on my system (w7 x64, FM-14.0.3.500) - the Help function does not work. Neither F1 nor selecting from the menu does anything.
Double clicking HelpViewer.exe correctly opens the online-help for FM-14 aka 2017.
Command Help in cmds.cfg is the same since years:
<Command Help
   <Label Help Topics...>
   <KeySequence \!fh>
   <Definition \x302>
   <Description Open Help...>
   <Mode All>>
Yes, there are some plug-ins and ExtendScripts, but as far as I see they do not manipulate the menu.
If I recall correctly there was an issue with HelpViewer.exe at the early versions of FM-14. Hence I had a copy of HelpViewer.exe from Fm-13 in use - but for the current release (build 500) the HelpViewer is OK.
What may be the culprit?
Klaus Daube
66
Likes
Reply
Community Guidelines
Have something to add?
Join the conversation
