Highlighted
Frame Maker 2017 has detected a serious problem and must quite giving internal error 14044, 26170801 etc..
Aug 29, 2018
Hello Team,
We are using Frame Maker 2017 on Windows 10 OS. While working on file getting below error.
(Frame Maker 2017 has detected a serious problem and must quite giving internal error 14044, 26170801 etc..)
Can you please help us to resolving above given error.
Also note that we are using FM 12 version on same system. Is there any conflict between two FM version.
TOPICS
Error
700
Likes
Community Guidelines
Aug 29, 2018
Hello Team,
TOPICS
Error
701
Likes
Aug 29, 2018 0
Aug 29, 2018
Conflict? no, you can run multiple versions of FM just fine (only Acrobat has issues with multiple versions).
Anyway, this is a user-to-user forum, so we're not being to be able to diagnose the hard error. Steps you can take first before contacting Adobe Support are - make sure you are all patched up; is it happening to all docs or just one? What are you doing when the error occurs? If it only happens with one doc, have you tried MIF-washing it?
Likes
Reply
Loading...
Aug 29, 2018 0
Aug 29, 2018
In addition to Jeff's suggestions
Likes
Reply
Loading...
Aug 29, 2018 0
Aug 30, 2018
Hi Team,
We have tried above given solution but still its getting same error and application crashes.
@Hi Jeff, All FM 2017 patch updated and its happening to all docs.
Likes
Reply
Loading...
Aug 30, 2018 0
Aug 30, 2018
Have you tried Matt's suggestion of deleting your Prefs folder?
Likes
Reply
Loading...
Aug 30, 2018 0
Aug 30, 2018
Deleting (or renaming) the prefs folder is quick, and rules out one possibility, but it seems your file is corrupt. Can you import the content into another document?
Likes
Reply
Loading...
Aug 30, 2018 0
Aug 30, 2018
We have tried renaming the prefs folder but no luck. as we have checked with Adobe Chat they provided one solution so that we will try and let you know if its work.
Likes
Reply
Loading...
Aug 30, 2018 0
