Need help deciding what to purchase if need 2 licenses for Framemaker and Acrobat Pro.
Aug 24, 2016
We are a small book publisher and are currently using Framemaker 10. We need to upgrade and could use help deciding what is best to purchase. We have 2 users using both Framemaker and Acrobat Pro. Thanks.
56
Likes
Reply
Community Guidelines
Aug 24, 2016
Are you trying to decide between FrameMaker and InDesign, or between various versions of FrameMaker? Either way, you will want Adobe Acrobat, of course.
Likes
Reply
