Highlighted
How to interact with extendscript engine without using ESTK or VSCode extension?
Mar 13, 2020
I'm researching how feasible it would be to write my own program to interact with the extendscript engine in illustrator. My goal would be to create my own ESTK replacement. AI script guide says that the ESTK uses BridgeTalk to communicate with Illustrator. How do I use BridgeTalk outside of ESTK? There must be a way to do this because the VSCode extension must be using some mechanism to interact with Illustrator.
Any information you can provide will be greatly appreciated.
TOPICS
Scripting
350
Likes
Community Guidelines
Mar 13, 2020
TOPICS
Scripting
351
Likes
Mar 13, 2020 0
Mar 13, 2020
I always use my Extension to write short snippets and run quickly.
AFAIK, BridgeTalk's socket definition is not disclosed yet.
Probably, You can capture the internal packet.
Likes
Reply
Loading...
Mar 13, 2020 0
Mar 13, 2020
An extension won't work for me because in some of my scripts I have to restart Illustrator. Is anyone familiar with how the VSCode debugger is able to connect to Illustrator to debug scripts? Is it also using BridgeTalk?
Likes
Reply
Loading...
Mar 13, 2020 0
Mar 14, 2020
I don't personally know how it works, but I believe it's all on github, no?
edit:
here it is.
https://github.com/Hennamann/ExtendScript-for-Visual-Studio-Code
Likes
Reply
Loading...
Mar 14, 2020 0
Mar 15, 2020
That is an ExtendScript code completion plugin.
We can search opened internal ports and capture some packets on our PC.
Likes
Reply
Loading...
Mar 15, 2020 0
Mar 15, 2020
I am currently using this extension to run/debug illustrator scripts. It does have an autocomplete component, but it does also communicate with illustrator to run extendscripts..
Unless this totally separate thing just happens to have the same name as the extension I'm using.
Likes
Reply
Loading...
Mar 15, 2020 0
Explorer ,
Jun 16, 2020
Did you make any progress on this? I'm trying to interact from a node application and I'm wondering the same thing.
As far as I can tell the extension William is referencing is the Adobe Extendscript Debugger that doesn't seem to be open source yet.
Likes
Reply
Loading...
Jun 16, 2020 0
Jun 16, 2020
Unfortunately, I was mistaken. I saw things on github that I thought were related to the debugger itself.. But it turns out that I was only seeing the syntax highlighting stuff. I don't know if we do have access to the underlying structure of the debugger itself. =(
Likes
Reply
Loading...
Jun 16, 2020 0
Resources
