Highlighted
Is there a shortcut for this? Changing size of objects with certain parts not changing.
Explorer ,
May 22, 2020
Hi, I wan't to know if there's a quick shortcut for this process that I usually do. Is there a way for me to quickly change up the scale of a certain object/element made up of different shapes, but with only some parts of it changing?
For example, like the object in this picture below, it's made up of different shapes, but the shapes has a pattern on how it will transform when the entire object's size changes. When scaled up or down, only the Yellow Circle and the Green Square can change their sizes fully. The Light Blue Rectangles at the sides and bottom can only increase in length, and the Dark Blue squares at the bottom corners must remain unchanged.
I want to know if there's a method where I can quicky adjust an object like the one in the picture, where I don't have to manually edit some of its parts.
Adobe Community Professional
Correct answer by Luke Jennings3 | Adobe Community Professional
Another method to get close to what you want is to create the border entirely out of strokes and turning off the preference to scale strokes and effects.
Use offset path and a dashed stroke to make the double stroke and corner squares. In order for the dash to work, you will need to select the Aligns dashes to corners and path ends, adjusting lengths to fit option. I used 0 pt. dash and 400 pt. gap. Also, the align dash option only works when the stroke is aligned to the center, so the unwanted parts of the corner squares need to be covered by an additional white stroke around the outside, which could be a problem if the shapes are used on a colored background.
Topics
Draw and design, How to
357
Likes
Community Guidelines
Explorer ,
May 22, 2020
Topics
358
Likes
May 23, 2020
You can get pretty close to your challenge converting a set of shapes to a Symbol and checking the Enable Gides for 9 Slice Scaling box.
What's inside those guides gets scaled,
Usually you can get two responses but not three different ones at the same time, in these situations you will get to partially select those shapes or apply one transform after another.
Shown below is -exactly- what you are after, I think.
Likes
Reply
Loading...
May 23, 2020
Likes
Reply
Loading...
Zernolf LATEST
Explorer ,
May 24, 2020
Oh, thank you very much, sorry for the late replies. I'll try these two methods out.
Likes
Reply
Loading...
