Align right edge with left edge of objects
Feb 11, 2018 Feb 11, 2018
I know you are able to align the left edges of objects and align right edges of objects, but is there a shortcut to align the right edge of one object to the left edge of another object? I want to make sure that the two objects are perfectly next to each other.
2.6K
Likes
translate
Community Guidelines
Adobe Community Professional , Feb 11, 2018 Feb 11, 2018
There's also the Distribute Horizontal Space button in the Align panel. Check Use Spacing and set the space to 0
Likes
translate
Most Valuable Participant ,
That’s where smart guides come in handy. Use them. Smart guides will help, too.
Likes
translate
Likes
translate
Align To Key Object
Tutorial: https://indesignsecrets.com/align-to-key-object.php
Graphic Designer Educator / PrePress Consultant
Likes
translate
Explorer ,
Oct 20, 2020 Oct 20, 2020
This is very clever and solves my issue ! thanks so much !
Likes
translate
Feb 12, 2018 Feb 12, 2018
Hi bv69 ,
If you have two or more objects to align will the before/after situation below describe what you want?
Note the object directly below the yellow key object!
Before aligning to the right edge of the key object:
After alignment:
I think, that the above can only be done by scripting.
Uwe
Likes
translate
Apr 23, 2019 Apr 23, 2019
Although the question is more than an year old but let me answer it.
Before there was option of 'pixel perfect' I didn't bother much to find the answer to this conundrum.
But now I do precise drafting using illustrator and thus have to keep an eye on X and Y coordinates. You might have gotten the answer through this reference by now
Just find the coordinates of X by aligning the Reference Point to the right edge and position other objects X coordinate to this point by aligning the Reference Point to the Left edge.
Likes
translate
Explorer ,
Oct 19, 2020 Oct 19, 2020
Often to make complexe shape symetrical it is nice to do one half then Oject > Transform > Reflect and copy. Any simpler way to exactly align the left and right halves ?
Likes
translate
