Bold heads, regular body: help importing styles
Jul 08, 2021 Jul 08, 2021
For years, I could import a (vendor list) that has bold heads and a standard body. Helvetica.
Now, InDesign doesn't see that different font styles of bold and regular. any help is appreciated!
TOPICS
Print , Type
186
Guide ,
Jul 09, 2021 Jul 09, 2021
Try to place your text in indesign as .rtf.
Try also .doc and .docx.
Is the result always the same?
Votes
Jul 16, 2021 Jul 16, 2021
.doc worked!
I have a vendor using wordperfect. Convert to a .doc and worked. Thanks!
Votes
And check your import options to be sure you are preserving formatting.
Votes
Jul 12, 2021 Jul 12, 2021
Hi Mark,
before import make sure that you did select the character style [None] in the Character Styles panel.
Uwe Laubender
( ACP )
Votes
Got it fixed. THANKS!!!
Votes
Please tell us how?
~ Jane
Votes
Hi Mark,
as a workaround you could also try a script by Marc Autret if you do copy/paste from Word to InDesign.
See into:
RichPaste | Copy and Paste with Minimal Formatting [UPDATE]
Marc Autret, April 06, 2016
https://www.indiscripts.com/post/2015/10/richpaste-copy-and-paste-with-minimal-formatting
Uwe Laubender
( ACP )
Votes
