InDesign Problems; Need Help
Community Beginner ,
Sep 30, 2020 Sep 30, 2020
I am using a 1 year old iMac with MacOS 10.15.7.
1. Indesign won't quit; you can select quit in menu but nothing hppes. I have to force quit to restart computer.
2. InDesign doesn't delete .idlk files when I close the file. In fact, with file closed, is I delete a residue .idlk file, it reappears.
3. When reopening after a forced quit, InDesign opens 10-12 "old", previously closed files.
I have:
1. Deleted preferences.
2. Uninstalled and reinstalled InDesign.
3. Deleted InDesign recovery files in InDesign cache.
Open to suggestions.
Bill Hinger
TOPICS
Bug , Performance
536
Community Expert , Sep 30, 2020 Sep 30, 2020
Hi Bill:
I deleted only the recovery files, I didn't delete the entire cache.
Then I would move on to rebuilding the cache/preferences. It you are nervous about it, you can move the files/folders to the desktop, or rename them, in lieu of deleting them. Be sure to read the entire post before starting.
~Barb
Votes
Advocate ,
Are your other CC apps working OK?
Votes
No problems with any other CC apps.
Votes
I'm not clear if this means you deleted the InDesign cache (or just the recovery files).
https://www.rockymountaintraining.com/adobe-indesign-rebuilding-preferences-cache/
Where are you saving the InDesign files? A local drive? Network drive? Dropbox or similar?
And when did this start happening? Was it right after the very recent 10.15.7 update or was it happening before?
~Barb
Votes
It is on a local drive.
It actually started happening about a week ago, which was prior to the latest system update.
Bill
Votes
Hi Bill:
~Barb
Votes
Deleting the entire cache worked. Thanks so much!
Bill
Votes
Great news, Bill!
~Barb
Votes
