Scale a text box with cmd and shift does not work?
Engaged ,
Sep 20, 2020 Sep 20, 2020
I used to be able to scale a text box with cmd and shift and the text would scale with the text box
I am using Indesign CC version 15.1.2, and this doesn't happen.  Why?
TOPICS
Bug
92
Likes
translate
Community Guidelines
The same key shortcut is still valid. Is it possible to re-enter the same key shortcut by deleting it?
Can you check it again when you rebuild it from the Keyboard Shortcuts tab in the edit menu?
Graphic Designer Educator / PrePress Consultant
Likes
translate
Engaged ,
Sep 29, 2020 Sep 29, 2020
Sorry, my late answer.
I don't really know what you mean? Have no idea what to do. But the "cmd and shift" does not work for me
Likes
translate
Hi haneadino,
this came up today:
Cannot copy or transform proportionally with latest InDesign and Mac Catalina
KarinM-Lou, 5 hours ago
https://community.adobe.com/t5/indesign/cannot-copy-or-transform-proportionally-with-latest-indesign...
Are you on Mac OS X 15 Catalina ?
Uwe Laubender
( ACP )
Likes
translate
Engaged ,
I have this version
Likes
translate
