Highlighted
Beginners info required for Tone Curve and Point Curve
Apr 16, 2020
Hi, new to photography and lightrooms here...
Trying to learn everything I can before I edit my honeymoon pictures (South African safari). I'm finding it hard to find specific information regarding Lightrooms CC in general as most guides are for the Classic.
Anyway.. I can't find a detailed defination of the difference between the Tone Curve and the Point Curve - and how to use them. Would someone mind pointing me in the right direction ?
Thank you,
Bradley
Adobe Community Professional
Correct answer by WobertC | Adobe Community Professional
The Guides for Lightroom-Classic can be adapted for Lightroom-Desktop (Lightroom on a Laptop)
Basically there are two views in Lr-Desktop (and Lr-Classic)-
1) Tone Curve:  Where you are limited to a large degree and can only move the curve in sections (Shadows, highlights, etc). You will see a grey area appear when you use the Curve in this manner, and only one point on the curve that slides up/down. (Basically doing the same as the Tone sliders in the 'Light' panel would be doing)
2) Point Curve: Gives you free-rein to add multiple points to the curve line and move them any-which-way you want.
In 'Point-Curve' mode the Curve panel works in a similar manner to most other software (eg. Photoshop)
https://digital-photography-school.com/make-color-adjustments-using-tone-curves-lightroom/
TOPICS
How to, Windows
132
Likes
Community Guidelines
Apr 16, 2020
Thank you,
Bradley
TOPICS
How to, Windows
133
Likes
Apr 16, 2020 0
Apr 16, 2020
Regards. My System: Lr-Classic 10.0, Photoshop 22.0, Lightroom 4.0, Windows-10. Nikon DSLR.
Likes
Reply
Loading...
Apr 16, 2020 0
Apr 17, 2020
Thank you. I think I get it now... it's the same axis for both charts but Tone Curve is targeted and the Point Curve offers more freedom.
Likes
Reply
Loading...
Apr 17, 2020 0
